Digibeta capture preset to use into FCP?
Got a problem and need help,
I’ve a Digibeta deck with a firewire out and need to capture the footage into FCP.
I’m using:
Powerbook G4
Lacie PCI card with 2 FW 800 ports and 1 FW400
Sony J-30SDImy question is what codec and capture preset should I use in FCP?
The footage was shot in 16:9 PAL on a digibeta camera- unkonwn if it was in anamorphic mode but the cameraman is a pro and says he always shoots just in 16:9So:
1. What capture codecs do I use
2. What sequence codec should I use (probably the same?)anyhelp would be great!!
