Activity › Forums › Apple Final Cut Pro Legacy › Difficulty with direct select
  • Difficulty with direct select
    Posted by Conor Toumarkine on March 26, 2010 at 1:03 am
    When I use the direct select tool to trim off the end of a clip I am only grabbing one of the three elements of the clip (video, L-Audio, R-Audio). It doesn’t seem to matter whether Command-L (Clip Linking)is enabled or not. I am only able to move one track at a time. On the same note if I use the blade feature I am only cutting one element of the track at a time rather then the whole link.
    Is there something I am doing wrong on the capture so that I have all elements of a clip linked separately? Is this a simple keyboard command that I have hit accidentally?
    This is driving nuts because for every one edit I used to do I now do three. Anyone out there know what I have accidentally done to cause this problem?
    Conor Toumarkine replied 16 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
