Activity › Forums › Adobe After Effects › Difficult shot – tips?
  • Difficult shot – tips?
    Posted by Alextaylor on February 17, 2007 at 9:37 pm
    I’ve got a shot (see it here: https://www.alextaylor.org/images/Picture-1.png) that I need to remove an element from – the address on the awning in the background. The character standing in front of it has fairly wiry hair, so it’s going to be rather difficult.. the shot is static for the most part, with the occasional small move here and there. I’m not too worried about the stability of the shot since it’s fairly static, but my biggest concern is obviously figuring out the best way to remove that address. At the very end of the shot he walks out of the shot, so I have a clean shot I can work from.
    My ideas so far are to attempt to just key out the white of the address and replace it with green, but I have a feeling that will look really messy. I could also make a clean awning from the end of the shot, and put it over the rest of the shot, using a mask or paint around his head. What do you think is the best way of going about this shot? Any tips are much appreciated!
    Alextaylor replied 19 years, 7 months ago 3 Members · 4 Replies
  • Andrew Kramer
    February 18, 2007 at 1:14 am
    Track the background. Make a green layer to overlay on the address, use a bit of feathering on the green so it blends well. Then use a subtract mask and roto the foreground charachter. With the right feathering it should look good.
    If you can get away with it you could always just take the “1” off the address. But I’m not sure your reasoning for doing so…
    Andrew
  • Bret Williams
    February 18, 2007 at 6:47 am
    Instead of a green overlay, actually place the element you want there. No need to be green screening anything.
  • Andrew Kramer
    February 18, 2007 at 7:16 am
    Sorry I didn’t mean green screening, I mean use a clean plate of the green wall.
  • Alextaylor
    February 19, 2007 at 9:07 am
    Thanks for the tips, guys! Hopefully feathering will do the trick though, I’m nervous about that wispy hair. I’ll see how it goes though!
