Activity Forums Maxon Cinema 4D Different textures on opposite sides of a polygon
  • Different textures on opposite sides of a polygon
    Posted by Robyn Rhodes on August 18, 2011 at 8:05 pm
    is it possible to apply a seperate texture on either side of a polygon, as in front side backside? A polygon with no depth in other words?
    thx,
    r
    I’m only half the thing I say I am, the other half are me.
    Adam Trachtenberg replied 15 years ago 4 Members · 3 Replies
  • David Biederbeck
    August 18, 2011 at 9:44 pm
  • Brian Jones
    August 18, 2011 at 10:37 pm
    you can also use the Front and Back Side settings in the Texture tags
  • Adam Trachtenberg
    August 19, 2011 at 12:15 am
    Another option is to use the Effects>Normal Direction shader inside a layer shader.
    So it would go:
    shader1
    normal direction shader (mode set to layer mask)
    shader2
    That way you can do it with a single material. If that floats your boat….
