Activity Forums Apple Final Cut Pro Legacy Different frame size and rate
  • Different frame size and rate
    Posted by Taila Wong on February 3, 2012 at 1:06 am
    Hi All,
    I have some footage shot with different cameras (lumix and 2 GO PRO cameras),and need to put all together in one timeline, I´m using Final Cut Pro 7. I already read some posts but cant understand which works for me. So this is what i have:
    Lumix:
    M2TS
    Frame Syze:1920×1080
    Frame Rate: 25 FPS
    Scan Type: interlaced
    Aspect Ratio: 16:9
    GO PRO 1:
    MP4
    Frame Size: 1280×960
    Frame Rate: 29.97 FPS
    Scan Type: Progressive
    Aspect Ratio: 4:3
    GO PRO 2:
    MP4
    Frame Size: 1280X720
    Frame Rate: 50 FPS
    Aspect Ratio: 16:9
    I think I should convert all to apple pro res 422, but i’m confuse to what frame size and rate should i choose.
    I want to do some slow motions too, what is the best option?? Conform in cinema tools??
    I try to convert 29fps with1280x960 to 25fps with 1280×720, but image looks flattened. when I convert 29 to 25fps without change the frame size, looks good, but i will still have to render this footage in final cut, and is not what i want.
    should i convert interlaced to progressive?
    I intend to deliver my movie to a boadcast channel and want to upload to youtube.
    I need to send a format that plays in PC too.
    Any and all advice would be appreciated!!
    Taila Wong replied 14 years, 7 months ago 1 Member · 1 Reply
  • Taila Wong
    February 3, 2012 at 6:26 pm
    Any idea??
    I really need help!!
