Activity Forums Canon DSLR Cameras Different Frame Rates 60, 30, 24 in the same sequence.
  • Different Frame Rates 60, 30, 24 in the same sequence.
    Posted by Alex Hodges on December 9, 2011 at 7:16 pm
    Hello all, I’ve heard the golden rule is to put lower fps footage into the higher frame rate sequence, as opposed to the other way around.
    I am working with shots in 23.98 fps, 59.94 fps, and 29.97 fps
    Put them in the mpeg streamclip for the same frame size at 1280×720,
    compressed with Apple ProRes 422, with my Pixel Aspect is Square.
    Sequence settings
    Frame Size: 1280 x 720 HDTV 720p (16:9)
    Aspect Ratio: Square
    Field Dominance: None
    Editing Timebase is 29.97
    Compressor: Apple ProRes 422
    Quality: 100%
    My Video Processing is on: Render 10-bit material in high precision YUV
    Not sure if that’s right. I want to achieve the fluid look of the 60, maybe put it into twixtor, and keep the look of the 24 and or 30 shots….
    -Alex
    Alex Hodges replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
