Activity Forums Adobe Premiere Pro Different Frame Rate footage
  • Different Frame Rate footage
    Posted by Johnny Hizz on July 30, 2012 at 3:22 pm
    I filmed a wedding this past weekend on two GH1’s I was filming at 1920 x 1080 24p, to my horror my wife had her camera set to 1280×720 60p(59.94) is there anyway I can convert the footage to match mine?
    Chris Tompkins replied 14 years, 1 month ago 2 Members · 1 Reply
  • Chris Tompkins
    July 30, 2012 at 6:24 pm
    Not the end of the world, at least they are both progressive.
    Drop the 1280/60 stuff onto a new sequence and make a match.
    Use this is for your edit. Drop in the 1080/24 into that sequence and don’t change the sequence settings, it will need to render, but you gain room to move on the frame. You can shrink back the 1080 stuff by 33% and can move around the frame etc.
    The 24p look will not be the same.
    Run a test with a few shots, make a DVD or bluray disc and view it in the living room.
    Chris Tompkins
    Video Atlanta LLC
