Activity › Forums › VEGAS Pro › Difference in MP4 Properties
  • Difference in MP4 Properties
    Posted by Joseph Ripley on December 16, 2015 at 3:43 pm
    Doing a cross comparison analysis between the original MP4 I downloaded to that where I rendered into a new MP4. Wondering if I use the new Mp4 if that will provide a sharper quality since it is already in 1920×1080 format when rendering to m2v????
    Joseph Ripley replied 10 years, 9 months ago 3 Members · 3 Replies
  • Danny Hays
    December 16, 2015 at 5:07 pm
    If I’m understanding you, you downloaded an MP4,from the internet? Then made it into another MP4? Why? It was already an MP4. What is the resolution of the first one? Making a new one with a higher resolution is not going to improve the quality. Also every time you render a video, it takes a re compression hit.
    Danny Hays
    Samples of my Work can be seen here:
    https://www.youtube.com/user/ErnestDaniels/videos?view_as=public
  • John Rofrano
    December 16, 2015 at 5:14 pm
    As Danny pointed out, re-rednering low resolution video to a higher resolution does not improve the quality and may actually decrease it because the render itself is using a lossy codec.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Joseph Ripley
    December 16, 2015 at 5:39 pm
    From the JPEG I had posted with it, the original showed the resolution, data and etc. In the experiment, redoing into a 1920×1080 factor, everything increased in the cross comparison analysis which also made it bigger. Then using the new MP4 as a source to do in m2v may have a difference.
