Activity Forums Avid Media Composer difference in file size on capture
  • difference in file size on capture
    Posted by Nadim Shartouny on May 8, 2009 at 8:39 am
    Hey all
    What is the difference between DV25 and 1:1 MXF? I’ve recorded DV and want to capture to my computer through an avid Mojo SDI. The resolution is the same on both codecs but the file size reads different. 1:1 is bigger. If no change in resolution what is making my 1:1 file that much larger? and is this of any use to me? what is the extra info in there and would I need it? Is it just less color compression/higher color depth or am I all wrong?
    Nadim
    Michael Phillips replied 17 years, 4 months ago 2 Members · 1 Reply
  • Michael Phillips
    May 8, 2009 at 7:51 pm
    DV25 is a compressed format around 5:1. 1:1 is uncompressed, thus the ~5x difference in file size.
    Michael
    Michael Phillips
