Activity Forums Apple Final Cut Pro Legacy difference between loading multiclip from Viewer or Timeline
  • difference between loading multiclip from Viewer or Timeline
    Posted by Genevieve H. ritter on February 14, 2007 at 5:12 pm
    We recently did a two-camera shoot. Created a multi-clip using the inpoints of two separate clips. Then I loaded it into the Viewer, from the Browser to the Viewer. From the Viewer I did an overwrite edit of the multiclip into the Timeline. Then I did realtime playback and switched between the angles showing in the Viewer. It worked great, awesome. My question is this: What is the difference between doing it this way or if I would load the multiclip into the Viewer from the Timeline instead of to the Viewer from the Browser? The manual seems to note some kind of distinction between the two. Does it make some kind of difference when I go to apply effects later on? Definitely I want to try to make the clips match color/brightness values as much as possible using the Color Correctors. Thank you,
    Gen Ritter
    Genevieve H. ritter replied 19 years, 6 months ago 1 Member · 1 Reply
  • Genevieve H. ritter
    February 14, 2007 at 5:13 pm
    My title was wrong. It should be as above to the previous post.
