Activity › Forums › Panasonic Cameras › Difference between FILM CAM and VIDEO CAM?
  • Difference between FILM CAM and VIDEO CAM?
    Posted by Jack Niedenthal on November 18, 2011 at 5:01 am
    Is there any difference in the video quality between FILM CAM and VIDEO CAM when filming in say 720/24pN?
    Can you film some scenes using FILM CAM and some using VIDEO CAM in the same project, or will it not look good?
    For example, film some slow motion with the FILM CAM and combine it in a scene that uses VIDEO CAM.
    Jack Niedenthal
    Microwave Films of the Marshall Islands
    http://www.microwavefilms.org
    iMac i7 using Lion 10.7.x, HPX 170 using only one 64GB card
    Chris Tompkins replied 14 years, 10 months ago 3 Members · 3 Replies
  • Steve Eisen
    November 18, 2011 at 3:32 pm
    There is no difference in quality. Make sure if you are in Film mode shooting 24pn or 30pn that your frame rate is set to default. If not, you are either under or over-crancking your footage and there will be no audio recorded.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Jack Niedenthal
    November 18, 2011 at 8:31 pm
    Thanks Steve. And if I wanted to do a typical slow motion scene, I would create a Scene File and set Operation to Film Cam and the frame rate to 48 if shooting in 24pN?
    Jack Niedenthal
  • Chris Tompkins
    November 18, 2011 at 9:46 pm
    Jack, You need to spend some time with your new camera.
    You want VFR to shoot slo-mo in cam. Page 31 in the manual.
    Chris Tompkins
    Video Atlanta LLC
