Activity › Forums › RE:Vision Effects › Diferent results between Final Cut Studio 7 and Final Cut Express 4 versions?
  • Diferent results between Final Cut Studio 7 and Final Cut Express 4 versions?
    Posted by Gus Tozzer on September 1, 2011 at 12:47 pm
    Hello
    Please, I have a doubt. Is there a final result difference working with these two versions, I mean, each Final Cut version has a correspondent Twixtor version, but both of them give the same final results when the slow motion is applied? Both of these Twixtor versions have the same funcionatilies? If yes, why the price is so different? I’m fascinated about this plug-in and I’d like to solve this doubt before buy it.
    Gus Tozzer replied 15 years, 1 month ago 2 Members · 2 Replies
  • Pierre Jasmin
    September 1, 2011 at 4:07 pm
    The internal engine is the same but there sure is a lot less controls in the FCE version. You can see FCE in action here; https://help.revisionfx.com/tutorial/94/
    And Twixtor Express only works in FCE.
    And you can download the regular Twixtor to see the difference for yourself.
    Pierre
  • Gus Tozzer
    September 1, 2011 at 9:10 pm
    Thanks for your helpful reply Pierre.
    PS: Just correcting, Final Cut Pro 7 not Studio 7… 🙂
