Activity › Forums › Adobe After Effects › Didn’t migrate settings from 17.1.4 – can’t see layers with blend modes in comp
  • Didn’t migrate settings from 17.1.4 – can’t see layers with blend modes in comp
    Posted by Erika Tsuchiya on October 27, 2020 at 4:28 pm
    Adobe Cloud did an auto-update and when I tried to open a project I got a prompt asking if I want to migrate settings from the older version (17.1.4). I clicked do not migrate out of haste and now I can’t see my animated layers with blend modes in the main composition window. I can’t figure out how to manually migrate settings to the new version so I re-installed the older version but I still can’t see the layers. Any ideas? Thanks for your help.
    Michael Szalapski replied 5 years, 11 months ago 3 Members · 2 Replies
  • Walter Soyka
    October 27, 2020 at 4:38 pm
    Migrating preferences shouldn’t have anything to do with being able to see your work. You might try first clearing your cache (Edit > Purge > All memory & disk cache…). Otherwise, if you could post a screenshot that shows your whole UI, maybe we can see if there’s anything else amiss.
  • Michael Szalapski
    October 29, 2020 at 1:42 pm
    Walter is right, your preferences wouldn’t have anything to do with seeing your layers. More info on your project would be useful and, as Walter mentions, a picture is worth 1,000 words.
