Activity › Forums › Creative Community Conversations › Did not follow the advised Install for FCPX
  • Did not follow the advised Install for FCPX
    Posted by Robin Lewis on August 1, 2011 at 10:10 pm
    Ok quick question,
    I got FCPX on the first day and just installed it on the the same Disc as my FCP 7 and iIonly just saw the Apple recommended ways of doing this install.
    Everything seems to work fine so no probs yet but what problems did they think it was going to cause??
    Tee only thing i did was to install FCP X in to a folder called FCP 10 apps within the application folder.
    Anyone actually had any problems??
    Thomas Frank replied 15 years, 2 months ago 6 Members · 6 Replies
  • Devin Crane
    August 1, 2011 at 11:11 pm
    Not here. I’ve been using for over a month now and no issues.
  • Steve Connor
    August 1, 2011 at 11:16 pm
    Me too, FCP7 seems unaffected
    Steve Connor
    Adrenalin Television
    Have you tried “Search Posts”? Enlightenment may be there.
  • Everest Mokaeff
    August 2, 2011 at 11:46 am
    You’ll wind up w/ broken FCP7 and Motion 4 after installing fcpx updates. There is plenty of info on this. Don’t take my word for it – check for yourself.
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
  • Robin Lewis
    August 2, 2011 at 12:07 pm
    So anyone know the recommended partition size if you were to have a Snow leopard partition with FCP 7 on it???
    Only have a 500GB 7200PRM hard drive in my Macbook pro
  • Bob Tompkins
    August 2, 2011 at 1:41 pm
    I had one problem in that my Final Cut Server found the new Compressor which did not have my proxy settings for FCS. It would not create the proxys. I ended up just sliding the old Compressor out of the FCS application folder into applications and it worked fine.
  • Thomas Frank
    August 2, 2011 at 2:20 pm
    Yes you can have issues with FCP7 and compressor.
    For example FCP7 won’t see Compressor until you remove v.4 out of the Application folder.
