Activity Forums Adobe After Effects Did I miss something?
  • Did I miss something?
    Posted by Cody Campbell on December 27, 2007 at 5:32 am
    In Andrew Kramer’s last tutorial he cheats the DOF blurring on the text by hitting the draft3d button– I did this and it looked great while I was building my project, but when I rendered it the blur was back on the text — is there something I need to do before rendering or does this not really work? Thanks in advance!!!
    _Cody
    Austen Mathieson replied 18 years, 7 months ago 3 Members · 3 Replies
  • Darby Edelen
    December 27, 2007 at 8:56 am
    For those of us who aren’t familiar with the tutorial: what exactly are you trying to do?
    Enabling Draft 3D will disable depth of field blurring, as well as any lights/shadows. If you want to render it this way you can make those changes in the Render Settings in the Render Queue or you can disable your lights and turn your Camera’s depth of field off prior to render.
    Or I didn’t understand the problem…
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Austen Mathieson
    December 30, 2007 at 8:28 pm
    I have the same problem with text blur and POF, no one know how to get around this?
    Austen Mathieson
    Austentatious Productions
  • Austen Mathieson
    January 17, 2008 at 12:34 am
    I figured it out, at least one way, the only way in fact I could find.
    You hide the text layer by switching off the eye in the timeline and render out the particles at full uncompressed setting (or QT amimation) or save ram preview and import into project.
    Then turn the text back on, turn DOF off and hide the particle so you now only have a black BG with non blurred/no depth of field on the white text. Render that out and import.
    Make new comp with imported particle, add the imported text.
    Voila
    Austen Mathieson
