Activity › Forums › Apple Final Cut Pro Legacy › Diagonal; Frame
  • Diagonal; Frame
    Posted by Paul Boyer on March 16, 2006 at 7:49 pm
    Is there a way to make a diagonal frame in FCP ei … cut the frame in half along the diagonal) so that I can run two clips on the diagonal from each other in one frame?
    pb
    Paul Boyer replied 20 years, 6 months ago 2 Members · 2 Replies
  • Debe
    March 16, 2006 at 8:13 pm
    Try Effects>Video Filters>Matte>Four-Point Garbage Matte. Add to each layer of video.
    On one, change the point 1 data to be 0 & 0. On the other, change point 3 to be 0 & 0.
    If memory serves, the point 1 data change will mask off the top and left portion, and the point 3 will mask off the bottom and right portion.
    debe
  • Paul Boyer
    March 16, 2006 at 8:21 pm
    Thank you, that’s exactly it.
    pb
