Activity › Forums › Apple Final Cut Pro Legacy › DG Fastchannel HD – SD Conversion –
Jeremy Garchow replied 16 years, 5 months ago 5 Members · 23 Replies
Joseph Wilkins
September 11, 2009 at 6:48 pmOK great… so i just did, then opened in VLC to check it and all looked correct… except I can see interlacing… now I am just playing this on my apple monitor… I dont have a broadcast display to check it on… is it supposed to look like that?
Jeremy Garchow
September 11, 2009 at 6:54 pmYep as it’s 24p with pulldown. VLC won’t display interlacing correctly, but it will look good on TV. You need speicalized hardware to playback the DGFC mpeg on a broadcast monitor, unfortunately.
Jeremy
Jeremy Garchow
September 11, 2009 at 6:58 pm[Jeremy Garchow] “You need specialized hardware to playback the DGFC mpeg on a broadcast monitor, unfortunately. “
Also, in my experience, DGFC has decent QA and will call you with problems.
Jeremy
Joseph Wilkins
September 14, 2009 at 8:24 pmJeremy…
I just uploaded to DG only to get this response:
File ‘VERL1482.mpg’ uploaded by client ‘PROCR-NB’ contains a file format not supported by DG Systems or the file is corrupt.
Any ideas? I simply took my 720 24p footage and dropped it on your preset in Episode and uploaded the result to the DG system
Thanks for your continued help… I really owe you!
Jeremy Garchow
September 14, 2009 at 8:39 pmYeah, not sure. I use that same preset all the time and it passes and is verified.
What version of Episode do you have? Are you uploading to the dropbox or just their ftp?
Try this one:
Jeremy
Jeremy Garchow
September 15, 2009 at 12:56 pmOh, and another thing. They said that the file might be corrupt, so maybe it didn’t transfer over properly?
The preset should work as I have no problems.
Jeremy
Joseph Wilkins
September 15, 2009 at 1:12 pmAhh… that was it.. it did not fully upload…
thanks again my friend!
Jeremy Garchow
September 15, 2009 at 3:05 pm[joseph wilkins] “Ahh… that was it.. it did not fully upload…
thanks again my friend! “
No worries. Glad it’s working for you.
Jeremy
Chris Early
October 2, 2009 at 2:15 amJeremy– Will this preset also work with a source frame rate of 59.94? Thanks!
Mike Schrengohst
January 7, 2010 at 11:57 pmWhat about HD Delivery for DG Fast Channel?
I have to take a completed file to a post house…
Dump to HDCAM and Fed Ex…I would love to be able to encode a file a just FTP it…
