Activity Forums VEGAS Pro Device Not Fount – Print To Tape ? ?
  • Device Not Fount – Print To Tape ? ?
    Posted by Henry Panniell on October 2, 2006 at 12:15 pm
    I have completed my first project on Vegas 7 and I want to print to tape. I get the message that the device is not found. Its the same device used to capture the files. Its listed as OHIC 1394 IEEE in the preference menue. Its a Sony DHR1000 miniDV/Fullsize DV deck. How can I get this project to tape? ?
    Thanks – H
    Asus PC-DL Deluxe, dual3.2 Xeon, ATI Sapphire 9600 Atlantis, onboard sound
    Henry Panniell replied 19 years, 11 months ago 2 Members · 5 Replies
  • Mike Kujbida
    October 2, 2006 at 1:38 pm
    Try doing it through Vidcap and see if you have better luck.
  • Henry Panniell
    October 2, 2006 at 5:53 pm
    Thanks for the advice, I will try that when I get home from work this evening.
    Thanks – H
  • Henry Panniell
    October 3, 2006 at 12:45 am
    How do I load the file in the Video Capture window? ? It states there is not file loade.
    Thanks – H
  • Mike Kujbida
    October 3, 2006 at 1:17 am
    In a nutshell, open Vidcap, select the Print to Tape tab and then go file > open.
    For more info, open the help file in Vidcap and search for Print to Tape in the index. Make sure it’s not “Printing to Tape” as these aren’t the correct instructions. It’ll explain things clearly.
  • Henry Panniell
    October 3, 2006 at 5:19 am
    Thanks for the help, I use the manual method, and that worked good. I’ll fine tune everything else later, I just needed to get this off the computer and to the customer.
    Thanks – H
