Activity Forums Apple Final Cut Pro Legacy Device control for SONY HD deck PDV-2000
  • Device control for SONY HD deck PDV-2000
    Posted by Jean Baillargeon on October 2, 2008 at 4:17 pm
    Hi guys
    I was trying to make an edit to tape last night. I use an AJA Kona LH card and 9 pin control cable. There are a few control protocols that come with AJA as you know. The one that always work with Sony decks I,ve used in the past is the AJA Sony 29.97 VTR B mode…
    Here’s what happened. Even though both deck and AJA card were synchronized using the AJA HD sync box, the deck would perform the edit perfectly (in assemble mode) It would regen timecode at the point of recording… but when I played back the deck I would get this pixillated image, as though half the info in the picture was missing… Sound was fine, It all played back… except that the picture was essentially unusable.
    I ended up just crash recording, with vtr control set to local… which worked fine. That’s when I noticed a green light on the front panel that was lighting up in crash mode… and staying red in edit mode… The caption under the light read, condition something.
    The guy who rented me the deck said that this light indicates a failed communication condition between deck and source. Even though the capstan indicator on the deck was showing a lock, as well as indicating proper sync signal lock. he also mentionned that controlling this machine with avid rigs was always very finicky… but that it worked.
    So I tried every single device control that applied with same result…
    Anyone face this same issue before ???
    any thoughts appreciated.
    cheers
    Jean Baillargeon replied 17 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
