Activity Forums Adobe Premiere Pro Developing Video for 35mm Screen
  • Developing Video for 35mm Screen
    Posted by Roman Kosta on June 23, 2011 at 7:23 am
    Hi Guys,
    I am very much new to adobe. I need to develop a video with still pics in between to project on 35mm screen.
    Not sure where to start, I downloaded trail version and drop the video into sequencer but the size in editing screen of that video is too big it going out of the safe margins.
    My video size is : 720x 480 (1.2121)
    1054+04, 29.97 fps
    48000 Hz – Stereo
    Can any help me the size from sequence presets need to select in order to sequence it, also what size the still need to be in between the videos.
    Roman
    Roman Kosta replied 15 years, 2 months ago 2 Members · 2 Replies
  • Eric Sanders
    June 24, 2011 at 3:04 am
    Hi Roman,
    Though I’m not entirely sure what you mean by a 35mm screen, the resolution of your sequence setting is something you can think of as your ‘top end’ resolution. When you’re done with your edits, you can export to pretty much any size you like. If you provide some more details about the project you’re working on that might be helpful to give more targeted guidance.
    I think though what you’re describing is that your source video and stills are larger than the sequence. There’s an option called ‘Scale To Frame size’, which will automatically scale video frames down to fit within a particular sequence size. This is an option on a per-clip-in-timeline basis, and can be set to be the default in (win) Edit -> Preferences -> General -> Default scale to frame size (mac) Apple menu -> Preferences (etc).
    You can also adjust the size / scale / rotation of a clip in the timeline when you have it selected in the timeline using the ‘Effect Controls’ window, or if you just click on it in the program montior, you get into ‘direct manipulation mode’ where you can see the size and scale handles as you would in Photoshop, etc.
    Hope this helps.
    -EricS
  • Roman Kosta
    July 2, 2011 at 6:18 am
    Hi Eric,
    Apology for getting back to you so late.
    After the completion of editing in premier pro, I am using after effects to add transitions and text in between the videos and images.
    All I want to know is to play this composition on 35mm screen.
    Now I am not sure what resolution I need to use in order to export this composition and play it 35mm screen.
    Roman
