Activity › Forums › Apple Final Cut Pro › Determining the plugin effect
  • Determining the plugin effect
    Posted by Greg Ball on January 16, 2018 at 2:47 pm
    My hard drive crashed, and I had to start from scratch. My projects load fine, but I can’t figure out what effects were used in the timeline. All I get is the red box with the yellow triangle and exclamation point. Is there a way I can identify the effect so I can download it? Thanks for your help.
    Greg Ball, President
    Ball Media Innovations, Inc.
    https://www.ballmediainnovations.com
    Michael Hancock replied 8 years, 8 months ago 2 Members · 1 Reply
  • Michael Hancock
    January 16, 2018 at 2:49 pm
    Is the effect not listed in the Inspector when you select a clip?
    EDIT: You could download X-FX Handler. Export an XML of your sequence and import that into X-FX Handler and see if it lists all the effects you used.
    https://www.spherico.com/filmtools/X-Files/X-FXHandler/
    Michael Hancock
    Editor
