Activity Forums VEGAS Pro determine play time of DVD project
  • determine play time of DVD project
    Posted by Richard Klimesh on June 20, 2005 at 4:15 pm
    In DVDA3 is there a quick way to tell how many minutes long a project is, without adding up the sum of all the parts?
    Dennis Vogel replied 21 years ago 2 Members · 1 Reply
  • Dennis Vogel
    August 12, 2005 at 2:04 am
    When you add assets to your DVD project DVDA shows the estimated size in the lower right corner of the screen. It’s labeled “Disc Space Used”. I think it is often overestimated. The best thing to do is use a bitrate calculator so you can figure out what settings you need to get the desired size before you go into DVDA.
    Good luck.
    Dennis
