Activity › Forums › Adobe After Effects Expressions › detect certain letters in the first row of a text layer
  • detect certain letters in the first row of a text layer
    Posted by Detlef Maerz on December 10, 2021 at 10:24 am
    Hi guys,
    I’m searching for an expression to detect certain letters (Ä,Ö and Ü) in the first row of a text layer and return a boolean.
    Could you help me with the right function and notation?
    Detlef Maerz replied 4 years, 9 months ago 2 Members · 4 Replies
  • Filip Vandueren
    December 10, 2021 at 11:13 am
    Hi Detlef, here’s a method using regular expressions.
    I suppose that with the first Row, you mean the first line that is explicitly ended by a line-break, not a line that is automatically wrapped by a textbox ?
    firstline = thisComp.layer("txt").text.sourceText.split("\r")[0];
    booleanResult = /Ä|Ö|Ü/.test(firstline);
  • Detlef Maerz
    December 10, 2021 at 12:46 pm
    Yes, that’s what I meant. Works perfectly! Thank you very much! One additional question: what should the syntax look like for the last line?
  • Filip Vandueren
    December 10, 2021 at 1:26 pm
    something like this:
    lines = thisComp.layer("txt").text.sourceText.split("\r");
    firstline = lines[0];
    lastline = lines[lines.length-1];
    booleanResult = /Ä|Ö|Ü/.test(lastline);
  • Detlef Maerz
    December 11, 2021 at 3:01 pm
    Thank You, Filip! Really helpful! 👍
