Activity Forums Panasonic Cameras detail level
  • detail level
    Posted by Goran Myrendal on December 16, 2008 at 7:17 pm
    I have used Avid express pro to convert HD footage from my Panasonic HDX900 down to SD.
    First I converted the sequens from 1080i/50 to DV25 PAL and then I tried to do a digital cut to dvcam. The result is a wery soft image.
    I understand that the result of HD is sharper than SD. I guess the detail level should be set differently if the result should be shown in SD compared to HD
    Could anyone give me some input here. How do you set the detail level if the result will be shown in SD and how do you set it if the result will be shown in HD?
    Thank you
    Goran Myrendal replied 17 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
