Activity Forums DaVinci Resolve Detail in motion fx dropping off in Davinci Resolve
  • Detail in motion fx dropping off in Davinci Resolve
    Posted by Helen Browning on April 25, 2025 at 1:02 pm
    Hello, I recently sent an offline edit out of Premiere Pro (2024) to an online editor and the easing in and out of motion effects on the images are dropping off when he brings them into Davinci. Has anyone experienced this and found a solution? There are lots of stills in the film so it would be very time consuming to redo the movements manually… many thanks, Helen
    Helen Browning replied 1 year, 4 months ago 2 Members · 2 Replies
  • Michael Gissing
    April 27, 2025 at 11:14 pm
    The xml format will not transfer all values between systems. This is especially true if fx applied are proprietary plugins. The only way to get that across is to render the timeline in a hi rez codec and then split the timeline back into clips in Resolve to grade. This will mean no handles but the moves will be baked in. The splitting back to clips will obviously struggle with dissolves and transitions but it is possible to grade over transitions with keyframing.
    It is always a good idea to test the limitations of xml transfer long before hand over so you can plan around these limits
  • Helen Browning
    April 28, 2025 at 9:33 am
    Hi Michael,
    Thanks so much – most helpful!
    best wishes, Helen
