Activity Forums Apple Final Cut Pro Legacy Desperately need help
  • Desperately need help
    Posted by Niti Shah on November 16, 2006 at 6:58 am
    hello
    Guys I desperately need help. I am working in PAL SD format. When I use speed and dissolve together, many times the speed of clip get changed(later when i save and reopen the project). It
    Michael Gissing replied 19 years, 10 months ago 3 Members · 2 Replies
  • Renjith
    November 16, 2006 at 7:13 am
    try recapturing that clip only
  • Michael Gissing
    November 16, 2006 at 7:33 am
    Try putting the sped up clip on another layer and keyframe opacity down from 100 to 0 to fade the layer in or out, rather than use the dissolves. The shot that you are dissolving in to, extend on a layer below and opacity ramp it in using the same frames as the top layer. Hey presto a nice dissolve between the shots.
