Activity › Forums › Adobe After Effects › Design for Film
  • Design for Film
    Posted by Misha Fields on January 19, 2015 at 8:21 am
    Good afternoon guys. A noob question since there aint no one around that can answer me.
    What this means?
    Material specification
    Cinema onscreen ratio: Flat 1:1.85
    File format : DPX, Targa, Tiff sequence embedded in QT)
    Resolution : HD size (1920×1080 Pixels) up to 2K or 4k is recommend or Hires quicktime (codec : Uncompress or Prores – audio can be or PAL size (720×576 Pixels) is acceptable but result might not good
    Digital Beta material supplied is not advisable > distorted resolution.
    Audio : 5.1 or Stereo wav file (48kHz, 24bit) *For dolby mixing, Please prepare separate track of Music, VO & each SFX
    For cinema standard loudness 82-85 dB Leq
    *We recommend material of both image and sound in 24fps. same speed as for DCP!
    Tone at 1 k@-20db
    So if I use after effects film 2k preset (aspect ratio 1.32?) will the output look like crap?
    Tero Ahlfors replied 11 years, 8 months ago 3 Members · 2 Replies
  • Walter Soyka
    January 19, 2015 at 11:21 am
    That spec is not very specific.
    The 2K preset would certainly fall within it (provided you stick to the 1.85:1 aspect ratio).
    If you have questions, you should ask whomever provided you this spec. We can only make guesses about it.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Tero Ahlfors
    January 19, 2015 at 12:25 pm
    So are these guys making a DCP for you or what? 2K Flat 1,85.1 resolution is 1998×1080 so if they want a full hd file it will be so slightly cropped when it is made to the DCI specs.
