Activity Forums Apple Final Cut Pro Legacy Desaturate Highlights/Lows problem: strange behavior
  • Desaturate Highlights/Lows problem: strange behavior
    Posted by Andrew Shtern on September 20, 2005 at 12:03 pm
    I’m working with 10-bit uncompressed, non-interlaced footage. Never used this filter before (not needed), but when I’d try to – I’ve run into a strange problem: it seems, that output from desaturate highlights is became single fielded (it seems like filter assumed that my source video is interlaced, and throws out one field), so all edges become jagged and overall quality looks like half-res.
    Sequence field order is set to none, source field order – not set. Timeline playback is set to full quality, no dynamic settings or smth. As I mentioned before, all footages are non-interlaced, and sequence field order set to none (and full resolution of course). The strange thing is: when I look at preview of the desaturate effect (green line above the clip on timeline) everything seems to be ok, but when I try to render or export – here comes this strange thing. And all other effects works pretty well.
    Any suggestions?
    Thanks in advance.
    Andrew Shtern replied 20 years, 11 months ago 1 Member · 1 Reply
  • Andrew Shtern
    September 26, 2005 at 1:47 pm
    Am I alone with this problem?
