Activity › Forums › Adobe After Effects › depth of field or fog in AE 3D?
Posted by Joe Carusoe on April 3, 2006 at 4:50 ami’ve got a bunch of images moving off into 3d space in AE… how do i make them blur and move off into a fog in the distance?
thanks!
bAndrew Kramer replied 20 years, 6 months ago 4 Members · 3 Replies -
Andrew Yoole
April 3, 2006 at 5:22 amTo blur your images, you can either:
Add a blur effect to each layer, and manually keyframe the blur as the camera moves
or
Turn on Depth of Field in your Camera settings. You’ll need to experiment with focal lengths and blur amounts until you get what you want.
To add fog, you will need to generate the fog on a solid with Fractal Noise or a particle generator (CC Particle World, Trapcode Particular etc) or locate some stock footage of smoke/fog. It will then need to be positioned in 3D space multiple times between your objects, probably with keyframed opacity to increase the visibility of the fog as the camera moves away from it.
Andrew Kramer
April 3, 2006 at 7:01 amThis might be a start.
https://forums.creativecow.net/cgi-bin/new_page_wrapper.cgi?forumid=1&page=https://www.creativecow.net/articles/kramer_andrew/3dcompositing/index.htmlGood luck,
Andrew
