Activity Forums Adobe After Effects Depth of field issue
  • Depth of field issue
    Posted by Layne Haacke on February 16, 2010 at 6:30 pm
    Sorry to bring up this problem again, but I never saw a good answer to it.
    It is referenced in this previous thread.
    https://forums.creativecow.net/thread/2/970581#970680
    If I’m missing some simple setting let me know, but when I turn on Depth of Field this very pronounced banding/glitch appears.
    It’s easy to recreate.
    HD Comp
    solid layer (make it light gray it shows up a lot more) make 3d
    make Camera
    turn on depth of field
    put camera on an angle
    turn the blur level up quite a bit to 950%
    It will show up in the lower right corner
    (here is the camera info)
    Camera Options Zoom
    1866.67
    Camera Options Focus Distance
    2290.41
    Camera Options Aperture
    17.7165
    Camera Options Blur Level
    percent 950
    Transform Point of Interest
    X pixels Y pixels Z pixels
    752.412 659.678 -157.189
    Transform Position
    82.2217 1305.76 -1775.17
    Adrian Ridley replied 16 years, 7 months ago 3 Members · 3 Replies
  • Todd Kopriva
    February 16, 2010 at 7:37 pm
    Do you just see the banding when you preview in After Effects, or do you see it in output files, too?
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Layne Haacke
    February 16, 2010 at 9:33 pm
    It’s on the full resolution renders.
  • Adrian Ridley
    February 23, 2010 at 4:20 pm
    I’m having the same problem in preview and renders (attached). I have tried outputting at a color depth of 32 bit but I don’t have enough memory to create the blur. Please help.
    https://i1.creativecow.net/u/44962/final_00047.png
