Activity Forums Maxon Cinema 4D Depth of Field Camera
  • Depth of Field Camera
    Posted by Jon Herron on September 12, 2007 at 9:11 pm
    Does the depth of field in Post Effects need to be checked in order for the camera depth of field to work. Im confused by the documentation.
    Jon Herron replied 19 years ago 3 Members · 3 Replies
  • Adam Trachtenberg
    September 13, 2007 at 2:12 pm
    [Jon] “Does the depth of field in Post Effects need to be checked in order for the camera depth of field to work. Im confused by the documentation.”
    Yes.
  • Brian Jones
    September 13, 2007 at 2:27 pm
    I don’t get any blurring without it and if I remove the AR module (which the post effect is part of) I get no blurring but if you render a multipass and look at the Depth channel it is affects by the Depth of Field camera settings
  • Jon Herron
    September 13, 2007 at 7:22 pm
    Ok thanks. Looks like it needs to be selected.
