Activity Forums Apple Motion Depth map
  • Depth map
    Posted by Chaim Sztabzyb on April 8, 2008 at 1:03 am
    BH
    Hi! I have a 3D animation file and another movie file with it;’s corresponding “depth map” how do I apply the depth map to a filter?
    Burt Hazard replied 18 years, 1 month ago 2 Members · 1 Reply
  • Burt Hazard
    April 8, 2008 at 8:29 pm
    Hello again…yeah, I like this forum too.
    In Motion proper you can’t really (yet); I suppose that could be a reason to buy After Effects! 🙂
    In Shake, of course, there is a way to do this:
    [Shake, so Motion folks will have to bear with us, or just ignore us, whichever is easier!]
    1) Use a Reorder Node again to create your Shake z channel (rgbar)
    2) Feed that into a DepthSlice Node
    3) Then feed that into your main animation File-In node’s Mask input
    4) Adjust center, lo, and hi parameters in DepthSlice to literally slice different sections of your animation, based on the depth data
    5) Then in your main animation File-In, activate autoAlpha and add a File-Out and render with the Animation codec (colors+)
    You’d have to do this several times obviously to get each depth layer, but then you could separately filter each one in Motion, then do the final composite back in Shake.
