Activity › Forums › Adobe Premiere Pro › Denoiser works in project but adds a hiss to audio track once exported
  • Denoiser works in project but adds a hiss to audio track once exported
    Posted by Sarah Liebman on June 11, 2015 at 11:39 pm
    I used Denoiser to get rid of excess ambient noise and clarify my audio in some interviews. It worked in the project, however once I export ited, a new hiss happens in the audio track before people start speaking. Once they start speaking the audio sounds fine. How do I fix this and why is it happening?
    Thank you for your help!
    Simon Billington replied 11 years, 3 months ago 3 Members · 2 Replies
  • Joe Barta iv
    June 12, 2015 at 1:46 pm
    Sounds like you need a Noise Gate. In the Premiere Audio Effects, add Dynamics to the clip or track. In the Effects Controls window select Dynamics > Edit. Check the AutoGate box. If you find that some words are getting clipped off when their voice goes softer, adjust the Threshold down. Also, having the Compressor box checked will help with your dialog too.
    Joe
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
    http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
  • Simon Billington
    June 23, 2015 at 9:52 am
    If you can’t reasonable results from the above suggestion, you can try out some of the 3rd party effects from here, such as NS1 or W43.
