Activity › Forums › Apple Final Cut Pro Legacy › Dell UltraSharp 2405FPW 24″ LCD Monitor
Posted by Ron on March 13, 2006 at 1:45 amanybody try this with FCP and HD footage ?
Dell UltraSharp 2405FPW 24″ LCD MonitorShane Ross replied 20 years, 6 months ago 4 Members · 5 Replies -
Walter Biscardi
March 13, 2006 at 1:52 amHave you done a search on this forum for that monitor? I believe that monitor has been discussed quite a bit on here.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Shane Ross
March 13, 2006 at 2:40 amRead this:
https://homepage.mac.com/comeback/iblog/Work/B787268209/C836512295/E20060126005104/index.html
I was able to get the HD Link to work after talking to a tech. Had some setting wrong in the System Preferences.
It looks GREAT…but still not optimal for Color Correction. Close, but no cigar. I mean…the footage loods darn good. But for broadcast, you still need a properly calibrated CRT, or broadcast HD LCD like the ecinemasystems monitor.
Shane
Alokut Productions
http://www.lfhd.net -
Sterling Noren
March 13, 2006 at 10:40 pmI use the Dell 24″ all the time with HDV footage in my home editing system. Since I only have one monitor I use the desktop cinema mode and switch to full screen for viewing. When i am done with an edit I take everything into another studio with a proper broadcast monitor to finish up.
But I am curious, since the HD Link supposedly gives pixel for pixel representation of the true HD resolution….what exactly am I seeing, and missing, on the LCD in desktop cinema mode in terms of resolution (not color or interlacing issues, just resolution itself)?
Thx
Sterling
Shane Ross
March 14, 2006 at 12:10 amThe monitor itself is not properly calibrated for color correction, and the colors, no matter how much you tweak, won’t ever match what a professional HD CRT or HD LCD monitor can represent.
I had an HD Expert look at mine, and set up the monitor to bars. He said it was darn close, and you could do initial color correction without a problem. But he would still leave the tweaking to the professional monitors.
He is a purist…and I am a purist. If you aren’t going to be critically looked at for color, then it will be fine. Unfortunately I wll be critically judged, so I don’t use it inthat way.
I keep it as a client monitor.
Shane
Alokut Productions
http://www.lfhd.net
