Activity Forums Blackmagic Design Dell 30” display qwith multibridge extream?
  • Dell 30” display qwith multibridge extream?
    Posted by Miles Blow on May 11, 2006 at 7:16 am
    Hi guys
    Just wondering if anyone here can recomend the dell 30inch display for use with the multibridge exteme. I’ve read through all the posts here and can’t seem to find anyone using this. Everyone here seems to be useing Quad g5’s with fcp.
    We are planning to use the dell/multibridge combo on a A8n32deluxe with a dualcore 4800 with 4gb ram….We are hoping to get 2k playback via the onboard 4channel sata raid with 4 300gb sata2 seagate drives,in premiere pro 2.
    Do you think this could work? I know this motherboard is certified…but it would be nice to know if anyone has got a similar setup up and running.
    Skavan replied 19 years, 11 months ago 3 Members · 5 Replies
  • Miles Blow
    May 31, 2006 at 12:20 pm
    I’ll reply seeing no one else did.
    The 4x300gb sata drives are giveing us about 208mbpsec. Still haven’t got the dell.
  • Kristian Lam
    June 1, 2006 at 6:34 am
    We’ve tested both the Apple and Dell 30″ and will recommend the Apple 30″ display as we’ve seen performace issues with the Dell.
    regards
    Kristian Lam
    Blackmagic Design
  • Miles Blow
    June 2, 2006 at 3:49 am
    Hi Christain
    We will look into that…Looks like we go the apple.
  • Miles Blow
    June 4, 2006 at 3:19 am
    Hi Kristian
    when you tested the two types of monitors ,what kind of performance issues did you see with the dell….is the refresh rate not fast enough….It’s just that we have already ordered the dell 30″?
  • Skavan
    September 10, 2006 at 7:34 pm
    I don;t know why you would see differences in favor of the Apple.
    It’s the same LG LCD panel in different housin with trivial differences in firmware implementation – the Dell is latest version, and new Cinema 30’s also use this panel.
