Activity › Forums › Apple Final Cut Pro Legacy › Dell 24″ users: Are you experiencing the 60Hz FCP frame dropping?
  • Dell 24″ users: Are you experiencing the 60Hz FCP frame dropping?
    Posted by Dan Brockett on January 8, 2006 at 1:41 am
    Hi all:
    I am very close to buying a Dell 24″ monitor for use with my new dual core 2.3Ghz G5 but now I have heard that even Apple is saying that there is a playback issue with G5s and FCP. Apple is recommending that the monitor is adjusted to 75 or 85Hz scanning rate, not 60Hz. The quote below is verbatim from the Barefeats website:
    January 6th, 2006 — FCP PLAYBACK PROBLEM REVEALED
    Readers have reported to me a problem with skipped frames during playback with Final Cut Pro on the Dell LCD display. According to an article on Apple’s site, monitors set to 60Hz refresh rate exhibit this problem. Their solution is to set the display at 75Hz or 85Hz. To my knowledge, the Dell FPW2405 (and FPW2005) can only be set to 60Hz when used on a Power Mac. Therefore, this is a major “gotcha” if you are running FCP on your Power Mac with a Dell LCD attached.
    Are any of you experiencing this? I cannot see how it would matter if you were using the Dell as an HD monitor using DVI but if you do want to use the Dell as a G5 monitor, could be an issue.
    Best,
    Dan
    http://www.biglittlefilms.com
    Shane Ross replied 20 years, 8 months ago 6 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    January 8, 2006 at 2:54 am
    I have two and I haven’t experienced anything of the sort. I just found that myself.
    Interesting.
    Shane
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Dan Brockett
    January 8, 2006 at 3:27 am
    Shane:
    Are you using your Dells as computer monitors or as video monitors for Hi-Def?
    Dan
  • Shane Ross
    January 8, 2006 at 3:53 am
    Computer monitors. On occassion I use Digital Cinema Desktop to see the image fullscreen, but that’s it.
    They don’t say how the monitors are used, only that people who use them report this.
    I suspect something else is the cause.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • David Slater
    January 8, 2006 at 6:53 am
    no problem here
    altho I am using a G4 rather then a G5 so I don’t know if that matters
    DAVE at Movies Rock in Toronto
  • Ed Dooley
    January 8, 2006 at 3:07 pm
    The Apple article is talking about CRTs, but barefeats has been getting reports of skipped frames with the 2405.
    He referenced the Apple article to say they are talking about CRTs.
    Ed
  • Ming Saadprai
    January 8, 2006 at 10:10 pm
    Did you guys mean frames dropping within the video in the 2405 itself? or on the external monitor?
  • Hayes1699
    January 11, 2006 at 3:33 pm
    i am using the kona LHE card on the new quadcore with 2 24” dells. The system is running off of a 3.5tb Xserve Raid. I HAVE experienced dropped frames on an DVCPRO50 project. We are buying new monitors today and shipping the dells back. The problem we are running in to – finding a monitor that works. Even the cinema displays dont specify the refresh rate.
  • Shane Ross
    January 11, 2006 at 5:45 pm
    What have you done to narrow it down to the Dell monitors? What makes you sure it is them, and not one of a dozen other reasons? I am just curious to know…
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
