Activity Forums Apple Final Cut Pro Legacy dell 2005fpw works w/ mxo, but where’s xdcam output?
  • dell 2005fpw works w/ mxo, but where’s xdcam output?
    Posted by Bill Snyder on April 24, 2008 at 9:42 pm
    I posted that I was having problems getting my mxo to work with my dell ultrasharp 2005fpw, but after tinkering a bit it works!
    It boils down to getting the display settings synced as closely as possible with the box.
    Now in FCP, I can select XDCAM 1080p 30 for my ingest settings but for external video it doesn’t have the same setting! I select uncompressed 1080p 29.97 YUV and it shows but it’s jumpy.
    Any ideas out there DXCAM users?
    Thanks so much for any help you can give!
    Bill Snyder 808-756-4608
    Chris Borjis replied 18 years, 4 months ago 2 Members · 1 Reply
  • Chris Borjis
    April 25, 2008 at 12:02 am
    can you set it for: MXO XDCAM HD 1080i 29.97?
    The frame rate and format has to match EXACTLY or you
    might have problems.
    Are you sure your XDCAM footage is 1080P and not 1080i?
