Activity Forums Panasonic Cameras Delkin SDHC Card Error – A Kind Of Fix
  • Delkin SDHC Card Error – A Kind Of Fix
    Posted by Daniel Brown on January 22, 2010 at 9:38 pm
    I had read that you could delete clips from the SDHC card when the camera was connected to the computer. Just click on and delete the clips in the PRIVATE>AVCHD>BDMV>STREAM folder.
    I tried that with a card with a single clip on it. When I ejected the camera and switched it to PB mode, it showed me something I’d never seen before. A “clip” that had a question mark icon on it. I couldn’t play the clip. I couldn’t delete it via the camera either. I figured the PLAYLIST folder on the disk must still have had the idea that the clip existed? (Not sure if that’s how the camera works)
    So like any naive and stupid person would, I decided to delete everything in the PRIVATE>AVCHD>BDMV>PLAYLIST folder too. Upon ejecting the camera and putting it into PB mode again, I got a horrible full screen error. “SYSTEM ERROR TURN POWER OFF”. Well shoot.
    So I did that, but I still had that error. I put in a new card to make sure it wasn’t my camera. Luckily the new card worked. When I put the bad card back in, I was at least able to have it mount to the computer. but when putting it in PB or CAM mode, I got the error again.
    So here’s what I did, written like your favorite recipe.
    1. Placed good card in camera
    2. Mounted on computer
    3. Copied the entire RIVATE>AVCHD>BDMV folder to the desktop
    4. Ejected camera
    Then…
    5. Placed bad card in camera
    6. Mounted on computer
    7. Copied the entire RIVATE>AVCHD>BDMV folder to the bad card
    8. Ejected camera
    And the bad card now works. With one stipulation. While the card had always told me that there was 99 minutes of record time when empty, now the card says 98 minutes of record time are available when the card is empty.
    So is 1 minute of footage still hidden in there? Do I have 1 minute of corrupted space? I don’t know. And I don’t plan to use this card for important projects unless I know it’s fixed or it can be fully fixed from this point.
    But in case this happens to you, hopefully this post helps.
    Lou Wirth replied 16 years ago 3 Members · 2 Replies
  • Gord Stephen
    January 23, 2010 at 4:12 pm
    Good to know, thanks. It’s best practise not to delete stuff from the card through the computer, only use the camera’s interface – there are metadata references, etc on the card that the camera knows about but you don’t.
    Now that the card works in the camera again, have you tried reformatting it? (Again… only in-camera.)
    Gord
    Gord Stephen, DP, Editor - Ottawa/Kingston, Ontario
  • Lou Wirth
    August 22, 2010 at 4:22 pm
    Is there a way to delete the clips inside the HMC150 without reformatting the card? I don’t want to lose my added scene files.
    thanks
    Lou
