Activity Forums Apple Final Cut Pro Legacy delivery with prores codec
  • delivery with prores codec
    Posted by Deren Abram on March 2, 2009 at 12:36 pm
    FCP version 6.0.3
    I’m to deliver a 73 minute project in QT ProRes (needs to be in range of 25-50GB) and would like some tips on doing this prior to exporting through compressor.
    Here are some general questions:
    1) prores vs prores HQ– which one and why?
    2) due to rendering multiple layers while going through compressor, should this be exported in smaller chunks (say 10 min. or so) and then brought back into fcp and re-exported as a whole? If so, is there any loss?
    Mac OSX 10.5.6
    Dual 1.8 GHz PowerPC G5
    4 GB DDR SDRAM
    Mac HD
    FCP Version 6.0.3
    Deren Abram replied 17 years, 6 months ago 3 Members · 6 Replies
  • Jerry Hofmann
    March 2, 2009 at 12:41 pm
    1. HQ should be used if you have a lot of motion in the video… like a car race, or lots of fast pans… otherwise use the standard ProRes settings.
    2. Nope, just export the whole deal… you don’t want to compress twice…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Deren Abram
    March 2, 2009 at 1:13 pm
    Thanks Jerry, I appreciate the help.
    Mac OSX 10.5.6
    4 GB DDR SDRAM
    Mac HD
    FCP Version 6.0.3
  • Dave Jenkins
    March 2, 2009 at 5:04 pm
    73 minutes in ProRes HQ SD 720×486 = 39.97 gigs
    73 minutes in ProRes HQ HD 1920×1080 = 136.76 gigs
    Dajen Productions, Santa Barbara, CA
    MacPro Two 2.8GHz Quad Core – AJA Kona LHe
    FCP 6.0.4 OS X 10.5.5 QT 7.5.5
  • Deren Abram
    March 2, 2009 at 6:48 pm
    Hey Dave,
    Thanks for the math. Project is 720p. So, what would is:
    73 minutes in ProRes HQ HD 1280×720 = (___?___) gigs
    BTW– what is the ratio formula?
    Sorry for the trouble. I really appreciate the help.
    Mac OSX 10.5.6
    4 GB DDR SDRAM
    Mac HD
    FCP Version 6.0.3
  • Dave Jenkins
    March 3, 2009 at 1:54 am
    I am using the AJA Data Rate Calculator. According to this program the 720P HQ is the same size as the 1080i HQ. 137 gigs and the bit rate is around 31mbs per second.
  • Deren Abram
    March 3, 2009 at 2:32 am
    Thanks. That really helps.
    Mac OSX 10.5.6
    4 GB DDR SDRAM
    Mac HD
    FCP Version 6.0.3
