Activity Forums Apple Final Cut Pro deleting like in FCP 7
  • deleting like in FCP 7
    Posted by Andy Borowa on August 26, 2011 at 3:17 pm
    How do I delete in “one click” all on storyline along with the primary storyline and everything else (audio, lower Thirds, music) from marker to marker as it was possibile in FCP 7.
    Sorry for my English
    Andy
    Pozdro
    Andy
    Andy Borowa replied 15 years ago 5 Members · 5 Replies
  • Jeremy Garchow
    August 26, 2011 at 3:51 pm
    Are you saying you want to select in to out, and delete?
  • Ben Scott
    August 26, 2011 at 4:12 pm
    only way i could find is make compound clip on area of the timeline with all elements you wish to cut
    then use your trim to selection tool (mark in out then alt )
    then break apart (once only be careful) the compound clip
    this is the only way
    its also impossible to trim across all elements unless you use this technique (not sure i think this is good)
  • Tom Wolsky
    August 26, 2011 at 4:18 pm
    You can use Cmd-B to cut across multiple items that are stacked in the Timeline.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2011 “Complete Training for FCPX” from Class on Demand
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • Andy Neil
    August 29, 2011 at 6:53 am
    Great tip Tom. I thought that had gone away. But the key is that you have to lasso all the tracks you wish to blade through otherwise it only cuts through the primary storyline.
    Andy
    https://www.timesavertutorials.com
  • Andy Borowa
    August 29, 2011 at 7:43 am
    … you have to lasso all the tracks you wish to blade through otherwise it only cuts through the primary storyline.
    That is problem “have to lasso”
    Pozdro
    Andy
