Deleting “flat line” audio lines from Vegas
Posted by Dandy Wellington on June 24, 2011 at 7:13 pmIn the attached image, I’d like to delete all the “flat line” audio lines and just leave the lines with a great amount of sound. Is there a quick and easy way to doing this? I’d appreciate a reply. Thanks a bunch!
Dandy Wellington replied 15 years, 3 months ago 3 Members · 8 Replies -
Mel Mcmurrin
June 24, 2011 at 9:57 pmIs your main problem with the flat line audio the disk space it wastes, the slight background noise it may contain, or the visual clutter?
(I’m assuming you wish to keep the video above the flat line audio. Correct?)
Dandy Wellington
June 24, 2011 at 11:24 pmHey Mel, Thanks for you reply. I don’t wish the keep the video within that specific time frames, and it’s the timing where the audio lies flat. In other words, if 0:15-0:40 contained flat lines, I wish to delete it along with the video that is within that time. Thanks.
Dandy Wellington
June 24, 2011 at 11:28 pmAfter looking at the other posts in this forum, I realized I may have posted in the wrong forum.
Danny Hays
June 25, 2011 at 12:28 pmClick on the event where the flat line starts and hit the s (split) key. Then do the same at the end of the flat line, then click somewhere in the flat line area and hit delete. Then drag the two remaing events together.
Dandy Wellington
June 25, 2011 at 6:04 pmHey Danny, thanks for your reply. I tried that technique you advised me on, but isn’t it essentially the same as adding markers and clicking the middle to delete it?
Danny Hays
June 25, 2011 at 11:01 pmYes it’s the same thing, different method. If you understand both methods, what are you having problems with?
Mel Mcmurrin
June 27, 2011 at 4:21 pmDandy,
Are you looking for some automated tool which will identify the flatline sections and perform the cuts for you? I don’t know if such a tool exists. I use Danny’s technique myself, with the added handy device of turning auto-ripple on which connects the pieces automatically. -
Dandy Wellington
June 27, 2011 at 7:30 pmMel, yes I thought such automated tool would exist! I’ll go with Danny’s technique then. Thanks Mel for the clear cut response!
