Activity Forums VEGAS Pro Deleting an Event Pan/Crop
  • Deleting an Event Pan/Crop
    Posted by John Lee on May 22, 2020 at 6:31 pm
    Magix 14.0 Pro. Let’s say I select a Pan/Crop. I then mess around and move some things. After finishing it, how do I go back and delete what I just did? I don’t see a way to remove the panning or cropping. Whenever I find myself in this situation, I have to resort to CTRL-Z until I’m back where I was before selecting the pan/crop.
    I’m sure it’s an easy answer, but I’m stumped. Thanks.
    John Lee replied 6 years, 3 months ago 3 Members · 5 Replies
  • Dimitrios Papadimitriou
    May 22, 2020 at 10:55 pm
    Right click on the key frames then select delete.
  • John Lee
    May 22, 2020 at 11:00 pm
    Thanks for the reply. That’s what I though should happen, but when I right click on “Pan/Crop”, nothing happens. I don’t see an option to delete it.
  • Francois Pénzes
    May 23, 2020 at 1:11 am
    Hi John
    Are you seeing this when you Right click ? If so , choose Restore.
    … or is it something else you want to do ?
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1 and a bunch of others
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
    May 23, 2020 at 2:09 am
    As said above, if you only have one keyframe you can’t delete it you have to restore it.
  • John Lee
    May 23, 2020 at 2:25 am
    Thank you! Now I get it. I see the “Restore” and clicking it returned the clip to normal.
    Much appreciated.
