Activity Forums Adobe Premiere Pro delete schema in metadata display
  • delete schema in metadata display
    Posted by Genevieve H. ritter on January 6, 2012 at 10:59 pm
    In Richard Harrington’s book, An Editor’s Guide to Adobe Premiere, on page 97 he shows you how to make your own schema as part of the metadata. How do you delete the schema once you create it if you no longer want that schema?
    Alexander Føsund replied 11 years, 4 months ago 3 Members · 2 Replies
  • Jan-philipp Langner
    February 20, 2014 at 10:12 am
    2 years later and i’m looking at the same problem. Did you find a solution?
  • Alexander Føsund
    April 29, 2015 at 10:55 am
    Just had the same problem!
    But I found out where the Schema metadata info is:
    Library/Application Support/Adobe/XMP/Custom File Info Pnales/4.0/custom/”Schema name”.xml
    Just delete this. Or if you want the info copied to a new machine, this is the file you need!
    Friendly Regards
    Alexander Føsund
    Assistent Editor/Editor
