Activity › Forums › Adobe After Effects Expressions › Delete layer marker with specific comment
  • Delete layer marker with specific comment
    Posted by Kevin Snyder on October 10, 2022 at 4:07 pm
    I’ve been looking through the AE scripting guide, and I’ve been able to write a script to add a layer marker with a comment, but how can I delete the same layer marker with the comment? I can’t seem to find the answer.
    Kevin Snyder replied 3 years, 11 months ago 2 Members · 6 Replies
  • Dan Ebberts
    October 10, 2022 at 6:43 pm
    I was surprised to find that removeKey() doesn’t accept markerComment as an index, so I guess you have to do it the brute force way:
    var myProp = app.project.activeItem.layer(1).property("Marker");
    for (var i = 1; i <= myProp.numKeys; i++){
    if (myProp.keyValue(i).comment == "test"){
    myProp.removeKey(i);
    break;
  • Kevin Snyder
    October 10, 2022 at 7:26 pm
    Thanks, Dan. I gave it a go and it doesn’t remove the key. I’m not getting an error message either.
  • Dan Ebberts
    October 10, 2022 at 7:35 pm
    It worked for me. It wouldn’t give an error if it didn’t find a marker with your comment (you did change that from “test”, yes?)
  • Kevin Snyder
    October 10, 2022 at 7:59 pm
    Okay, it’s working. I just changed it to run on the selected layer. Thank you.
  • Dan Ebberts
    October 10, 2022 at 8:17 pm
    This is probably better:
    try{
    var t = myProp.keyTime("test");
    var myKey = myProp.nearestKeyIndex(t);
    myProp.removeKey(myKey);
    }catch(e){
  • Kevin Snyder
    October 11, 2022 at 6:19 pm
    Thanks, Dan. I really appreciate it.
