Activity Forums Maxon Cinema 4D Delete inner/hidden polygons
  • Delete inner/hidden polygons
    Posted by Darren Lee on January 6, 2021 at 1:36 pm
    I’m trying to create a clean Boolean through a model from the C4D default library.
    So I’d like the slices to be capped, or joined.
    I’m assuming to get this, I’d need to delete all inner polygons. I’ve had a google and it doesn’t seem straight forward.
    What is the most efficeint way of doing this?
    Thank you
    sajjad abouei replied 1 year, 9 months ago 4 Members · 4 Replies
  • Michael Szalapski
    January 6, 2021 at 6:55 pm
    The quickest way would be to select one of them, hit the select connected command, and then delete them.
    But I’m not sure that would actually solve your problem. Which models are these (what version of C4D and where to find them in the browser)?
  • Darren Lee
    January 7, 2021 at 10:36 am
    Hi, it’s the model in the library here:
    As an experiment, I can join 2 simple cubes together using either the connect or Boole objects, but with more than 2 it doesn’t seem straight forward.
    I also tried Magic Merge plugin: https://www.youtube.com/watch?v=_2y2stgSJfg but that doesn’t seem to be able to handle it either
  • Ryan Palm
    May 19, 2022 at 1:46 pm
    I’m way late but for anyone who comes across it… I would try:
    Voronoi Fracture:
    -sources, delete sources
    -Selection, outsidefaces
    Then connect objects/current state to object to get back to your origianl poly, except now you have a poly selection tag of all of the outside faces.
    Deleting that will work in many of the cases.
  • sajjad abouei
    December 10, 2024 at 10:10 am
    I have a case which this didnt work
    but it is a brilliant idea i havent think of thank you man♥♥
