Activity › Forums › Apple Final Cut Pro Legacy › delete “favorite effect”
  • Jeremy Garchow
    January 27, 2010 at 4:44 pm
    Trash prefs, but then you lose them all.
    I don’t understand why you can’t just delete it out of the favorites bin in the effects tab?
  • Bob Cole
    January 27, 2010 at 5:42 pm
    [Jeremy Garchow] “I don’t understand why you can’t just delete it out of the favorites bin in the effects tab?”
    Of course! Thanks Jeremy.
  • Zac Self
    September 1, 2010 at 9:22 pm
    Where is the trash preferences at? Thanks
  • Bob Cole
    September 1, 2010 at 10:57 pm
    Hi Zak,
    This is a different issue from the thread. You might want to do a search for this answer, perhaps in the Final Cut Pro Basics Forum – it can get complicated. fwiw, it’s not inside FCP, and can be done either manually (you have to know where to find the preferences), or with a dedicated little program. I use Preferences Manager.
    Good luck!
    Bob C
  • Zac Self
    September 1, 2010 at 11:21 pm
    Thanks for your help.
    Zac
  • Michael Glover
    September 2, 2011 at 11:15 pm
    In the effects bin there is a folder called “favorites” just select the filter you want to remove and hit delete.
