Activity › Forums › Avid Media Composer › delete clips off drive
  • Chaz Shukat
    February 6, 2006 at 3:29 am
    Highlight the clips that you want to delete, then hit the delete button on your keyboard. You will be asked if you want to delete only the clip itself , or if you want to delete the associated media files, or both. It sounds like you want to clear the associated media from your drive, so be sure you select that option.
    There are other ways to delete media from your drives, but try this and I’ll let one of our other creative cows tell you about the other methods.
  • Ladymaya
    February 6, 2006 at 3:55 am
    i am only talking about the parts i cut off the clip
    is that what your talking about ]
    i dont want to dump the entire clip
  • Jon Zanone
    February 6, 2006 at 6:57 pm
    If you are talking about decomposing, it’s a fairly simple matter detailed in the manual.
    I do it like this –
    Create a new bin. Duplicate your finished sequence (highlight the clip and cmnd/cntrl D), and drag a copy into your new bin. Go to clip>decompose. You’ll get a dialog box which will allow you to adjust your ‘handles’. click OK, and the Avid will create new clips associated with that sequence, but with no media. You can then delete all your old media (assuming you labled your tapes and media correctly) and re-digitize your media to a higher resolution. This is particularly handy when using multicam, and was developed back when storage cost thousands per gig, instead of hundreds.
    If you are talking about a ‘crop’ function similiar to Photoshop where you can delete portions of the picture (or in this case, file) you don’t want, it doesn’t exsist. Most of this can be rectified in pre-production – going through your tapes and identifying specific shots you want to use.
    Jon
  • Ladymaya
    February 7, 2006 at 3:32 am
    iam running 3.52
    decompose can not be found in clip
    or anywhere else i have looked
    any suggestions
  • Chaz Shukat
    February 7, 2006 at 3:49 am
    If decomposing is what you want to do, and I’m not at all sure that it is, first you have to highlight the sequence that you want to decompose, then you will find decompose in bin menu.
    Chaz S.
  • Jon Zanone
    February 7, 2006 at 7:08 pm
    I’m not trying to be rude (sometimes I don’t have to work that hard at it, thought!), but have you consulted the help files and / or manuals that came with your system? There is a wealth of information regarding the Avid. There are some pretty good tutorials as well…
    You might want to search on decompose, and consolidate….
    Jon
  • Ladymaya
    February 8, 2006 at 1:26 am
    I do appreciate you giving me help
    but
    what makes you think I didn’t use the help menu or books I own
    maybe I was searching for some confirmation on what I was reading
    maybe you should check if 3.5 offered this option [decompose]
    and you didnt mention -consolidate-
    you need to remember Jon Zanone
    if your going to answer in this area be mindful
    its for new users as it states
  • Jon Zanone
    February 8, 2006 at 1:46 am
    Sorry. You can rest assured I won’t make that assumption again.
    Jon
