Activity Forums Zaxwerks Delete a Pose in ProAnimator
  • Delete a Pose in ProAnimator
    Posted by Joel Thiessen on October 16, 2009 at 5:12 am
    I’ve put an object pose in my timeline that I no longer want, only I’m out of undo’s. How do I delete, remove, or erase object and/or lighting poses?
    Stephen Smith replied 15 years, 11 months ago 3 Members · 2 Replies
  • Edward Wu
    October 16, 2009 at 4:44 pm
    Hi Joel,
    If you are working within ProAnimator, you can select any pose you’d like to delete, and press the “Delete” button on your keyboard. If you are working within ProAnimator FX, you will have to hold the “Alt” button, then the “Delete” button. The command will then delete the pose.
    In regards to the number of “Undos”, you can go into the ProAnimator Preferences menu to increase the number of “Undos” from “5” to a higher number.
    Best,
    Edward
  • Stephen Smith
    October 29, 2010 at 3:59 pm
    Edward,
    This is great, you are such a life saver!
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
