Activity Forums Adobe After Effects Expressions Delaying multiple transitions
  • Delaying multiple transitions
    Posted by Kevin Reiner on March 5, 2008 at 5:01 pm
    Hello all,
    I am trying to accomplish what is probably a simple expression, but I just can’t get my head around it.
    I have 35 horizontal lines that have the venetian blind transition applied. I made a null with “slider control” and then gave each layer an expression to follow the slider.
    thisComp.layer(“Null 1”).effect(“Slider Control”)(“Slider”)
    What I can’t figure out is how to delay some of the lines a certain number of frames.
    Any help would be greatly appreciated.
    Kevin
    System Setup (for a more detailed list, see my profile)
    HARDWARE
    Mac Pro 2 x 3 GHz Quad-Core Intel Xeon
    9GB Memory
    Two 16x SuperDrives
    Dual-channel 2Gb Fibre Channel PCI Express card
    Apple Cinema HD Display (23″ flat panel)
    ATI Radeon X1900 XT Graphics Card
    AJA Kona LHe SD/HD capture card
    Apple Xserve Raid 5.6TB
    SOFTWARE
    Mac OS X 10.4.10
    Final Cut Pro Studio
    After Effects CS3
    Photoshop CS3
    Illustrator CS3
    Boris Continuum
    Sapphire Plug Ins
    Roxio Toast
    Digital Anarchy Anarchist Suite
    ParticleIllusion 3.0
    Trapcode
    Zaxwerks
    Dan Ebberts replied 18 years, 6 months ago 2 Members · 1 Reply
  • Dan Ebberts
    March 5, 2008 at 5:06 pm
    This is one way:
    delay = 15; //delay in frames
    thisComp.layer(“Null 1”).effect(“Slider Control”)(“Slider”) .valueAtTime(time – delay*thisComp.frameDuration)
    You could also calculate the delay based on the layer index if the delay is different for each layer.
    Dan
