Activity Forums Apple Final Cut Pro Delay of import files dialogue box appearing
  • Delay of import files dialogue box appearing
    Posted by Brendan Gibbons on July 5, 2011 at 12:15 am
    As the subject says, I am experiencing a delay of almost 10 seconds of the file choser dialogue box appearing every time I choose to import files after creating a new event.
    Just doing tests on a 2011 imac, no other applications open. Same thing happens if the last location of the dialogue box was an external drive or a internal drive (naughty me I know – media on internal drives, just for tests mind you)
    Anyone else experience this at all?
    On a similar note, quite often when you move the mouse to the edit menu there will a delay of 2-3 seconds before the menu drops down. Now I don’t normally use the mouse to access menus as I’m a keyboard freak…just an observation.
    cheers,
    Brendan
    Brendan Gibbons replied 15 years, 2 months ago 2 Members · 4 Replies
  • Kevin P mcauliffe
    July 5, 2011 at 6:14 pm
    Hey Brendan,
    Did you try running ONYX on your machine. Any time I was having strange issues in FCP7, I would run ONYX, and it would clear up most issues. Here’s the link:
    https://www.titanium.free.frdownload.php?sid=b6a88d3b93b7130bcd2c597faf8f007f
    There is the usual warning to back up your drives before running ONYX, but I have been using it for years, and have never had an issue. I actually run ONYX every week on my system to keep it running in tip-top shape. Let me know if this works.
    Kevin P McAuliffe
    Creative COW Trainer
    kevinpmcauliffe@gmail.com
    Twitter: @kpmcauliffe
  • Brendan Gibbons
    July 5, 2011 at 6:21 pm
    I’ll give it a whirl and see if it helps, use to use on my laptop, it’s weird though as it’s a very new imac and hardly anything installed on it.
    Cheers,
    Brendan
  • Kevin P mcauliffe
    July 5, 2011 at 6:24 pm
    Trust me, doesn’t matter how new the system is. I have a super powerful Mac Pro tower I cut on every day, and a week into having it, was having permission problems. Ran Onyx. Problem solved. Keep me informed…..
    Kevin P McAuliffe
  • Brendan Gibbons
    July 6, 2011 at 7:54 am
    Still had the same problems persisting after running onyx…. was a fresh system so bit the bullet and did a clean install of the OS.
    The pleasure of messing with a non-production machine huh 😉
    cheers,
    Brendan
